So far, it looks like a m18 x 1.5 O2 sensor plug will work to plug the oil holes. I have one laying around and should fit fine. I just have to have the hole drilled a tad deeper (couple mm's) and then tapped. By doing it this way, if I or someone else wants to go back to stock, it will be easy to do. I have the tap but I think I'll have the machine shop do this for me. It should only set me back $40 bucks or so. I need to have the lower Dilivar studs removed and replaced with the steel ones at the same time anyway. |
To disable the thermostat all you have to do is remove the steel cap on the bottom end. It just pops off like a bottle cap. After that the guts fall out and you have a nice aluminum housing to install back in your engine. I don't think you'll have any need for a fan if you have air ducted to a good front cooler.
-Andy |
Block off plate options:
http://forums.pelicanparts.com/uploa...1295369001.jpg 91-92 965 turbo) 930 107 105 993) 993 107 105 959 / Air craft engine)959 107 105 And the ever popular, machine it yourself. http://forums.pelicanparts.com/uploa...1295369018.jpg http://forums.pelicanparts.com/uploa...1295369052.jpg http://forums.pelicanparts.com/uploa...1295369066.jpg http://forums.pelicanparts.com/uploa...1295369085.jpg |
Thank you for taking the time. I'll post up some photos of mine when I get it done for the benefit. |
One more thought: The early fan shroud works best when using a block off plate.
No ducting for the cooler. Just cut the intake openings to fit the head configuration and make a simple plate to direct the air around cylinder #6. see picture Here is a modified 3.6 http://forums.pelicanparts.com/uploa...1295372497.jpg 2.0 Potus engine http://forums.pelicanparts.com/uploa...1295372586.jpg 914-6 race engine http://forums.pelicanparts.com/uploa...1295372662.jpg |
Nice........ aircraft engine parts! Thanks for sharing the pictures Henry. Machine it yourself certainly does the job if no oil filter is desired!
Just in case anybody does a search for the part numbers; 993 part = 993 107 057 00 965 part = 930 107 057 01 959 part = have no clue, way out of my league! Currently the 993 part is 1/2 the cost of the 965 part. |
The 959 / Mooney aircraft engine part is 959 107 053 01. They have 6 in Germany and today's price is $1,532.92. Get yours quick, just like gold, the price is going up.
Cheers http://forums.pelicanparts.com/uploa...1295369066.jpg |
No offense to the OP, but you don't know for sure that you have a problem yet. And even if you do have a leak, by no means are all leaks terminal. At $65 invested, you have plenty of headroom before you're throwing good money after bad, IMHO.
If you'd prefer a delete plate to a cooler, perhaps you could sell the cooler you've got for what you paid for it, and do a quickie delete plate in your own shop from scratch? If I didn't already have two spares on the shelf, I'd be tempted at that price. Edit: just realized you probably have the later, non-threaded oil cooler. Dunno if those are worth beans. Cut away! :) |
| All times are GMT -8. The time now is 01:44 PM. |
