Rod bolts
Hi guys,has anyone used the 12.9 verbus rod bolts in their 2.7 street engine? And if so have you had any problems?Thanks,T.C.
Old 01-14-2011, 04:18 PM
Grade 12.9 Metric fasteners are specified with a minimum Yield Strength of 165 000psi and a minium Tensile Strength of 185 000psi.
Just a bit less than ARO 2000 series which are in the 215/220 000psi range so can accpet a bit more preload.
Certainly good enough for a stock 911S motor I would think but maybe a bit on the limit for 8000rpm race motors.
Old 01-16-2011, 10:19 AM
Thank you Chris.
Old 01-16-2011, 10:51 AM
