-   -   2.4 mfi distributor in a 3.0 case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/585688-2-4-mfi-distributor-3-0-case.html)
haycait911 01-15-2011 02:15 PM
some details of my experiment. I wanted a better curve than the stock SC dizzy for my webered 3.0. I could have the stock one recurved but I have a bunch of extras and parts laying around. I took the drive gear off a SC dizzy and put it on the 2.4. just drilled out the old pins, found a screw with the right diameter and used the shank to pin the gear. then a center punch to flare the ends. plugged it into the 3.0 case. I'll post running results once I fire it up.
http://forums.pelicanparts.com/uploa...1295129539.jpg
http://forums.pelicanparts.com/uploa...1295129560.jpg
http://forums.pelicanparts.com/uploa...1295129589.jpg
MBruns 01-15-2011 05:43 PM
dizzy
The SC rotation is CCW, the early dist is CW rotation. won't work
Mike Bruns JBRacing.com
haycait911 01-15-2011 11:44 PM
hi Mike. I think maybe you didn't read my post all the way through. I changed the drive gear on the dizzy to one from an SC.
anyway, after a few of the usual start-up issues, it's running. I need to get it tuned and dialed in then we'll see if the curve makes any difference.
Steve@Rennsport 01-16-2011 01:28 AM
I think what Mike was trying to tell you is that CW and CCW distributor advance mechanisms only function in one direction. So,.....if you rotate the 2.4 distributor CCW, you'll not get any centrifugal advance.
haycait911 01-16-2011 01:38 AM
oops. never thought of that. :confused: feeling a little silly. oh well, back to the drawing board.
MBruns 01-16-2011 05:17 AM
rotation
Exactly, We make a billet 6 pin distributor with a magnetic trigger for both rotations, if you like take a look at the website. Steve has used a few of them. They work well and you can change the springs and/or limit the total advance to make whatever you like for a curve.
Flat6pac 01-16-2011 06:12 AM
Or plan ahead and change the crank gear and the 2.4/ 2.7 stuff will all work.
Bruce
