HELP! SSI oil line/emission tube troubles
(76' 911s)I am in the middle of putting the new style oil lines for the SSI heat exchangers and have run into a problem. The emission tubes or whatever the tubes that are sticking out of the exhaust port are blocking the way for the oil line to fit correctly. I think i read somewhere that i can remove the entire system and plug the holes somehow but im not sure. How can I remove this system, does this mean i can take the pump off or whatever drives off the alternator too?
Old 02-12-2011, 10:25 AM
You will need to remove those air-injection tubes and associated plumbing, to fit the oil lines.
You can buy the plugs necessary to fill those holes from PP.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-12-2011, 10:55 AM
Got it thanks
Old 02-12-2011, 11:41 AM
