Canyon Runner
70SC's Avatar
Porsche Crest Camshaft endplate seal leak
Gotta cam seal leak question to ask. When redoing the cam endplate gasket /seals . Should i replace/ check the rocker shaft seals too, or is the main leakage problem usually the camshaft endplate seals? Thanks
Old 02-08-2011, 10:29 AM
The rocker shafts being in proper location adds to good oil seal.
Bruce
Old 02-08-2011, 12:51 PM
Alan L's Avatar
Depends where your oil is leaking from?
But normally there are no seals on the rocker shafts, unless after market fitted (or RSR).
They do seal fine without O rings if fitted properly and not damaged previously by some monkey with a wrench.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-08-2011, 10:06 PM
