-   -   identifying the rod bolts in my 79 930 engine--ARP or OEM? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/590324-identifying-rod-bolts-my-79-930-engine-arp-oem.html)
j911brick 06-15-2011 06:51 PM
Originally Posted by lucittm (Post 6081290)
It is a shame that someone would produce such a well-finished bolt and then not mark it with their name.
I have heard that many factors can affect the torque reading: thread friction, material friction under the nut, temperature, bolt twist, phase of the moon, etc. But bolt stretch is the engineered way of determining how "tight" the fastener is. I would not have expected a 20 ft. lb. difference in the two methods. Maybe ARP is adding a safety factor for folks without a stretch gauge or the ability to use it properly by decreasing the torque value read from a torque wrench?
Mark
I wonder if the rod material has much to do with the differences we're seeing? For example: if they set he standards/testing on CroMo/ Ti rods, would that be the same as forged steel rods?
