-   -   engine/transmission seperation (http://forums.pelicanparts.com/911-engine-rebuilding-forum/590678-engine-transmission-seperation.html)
porscheboy1 02-09-2011 08:29 AM
I recently removed the engine/transmission module from my 1978 911Sc. The engine and transmission are stuck together and so far I can't get them apart. Can get about 1/4" gap and that is all. What to do? The car has been sitting for several years.
opata 02-09-2011 09:01 AM
When I rebuilt my 80sc 3.0 I had to wiggle and pull a lot to get them to separate. I even used a piece of wood to pry them apart when there was a big enough crack to get the wood into..... I'm sure you'll get it apart...... and others will chime in that know a lot more than I do :)
Alan
pete3799 02-09-2011 09:18 AM
Are both arms off of the clutch fork shaft?
The shaft needs to be able to rotate (to disengage the throw out bearing) as they separate.
Flat6pac 02-09-2011 09:38 AM
+1 on Pete
tctnd 02-09-2011 10:04 AM
Was it having shifting problems? If the pilot bearing has frozen it can spin on and weld itself to the input shaft. That can be very difficult to separate,.
regards,
Phil
porscheboy1 02-09-2011 04:57 PM
Thanks Pete, I removed the levers and the transmission came right off.
John
