Piston Squirters
I have been searching and reading about piston squirters. Seems the turbo squirters have a hole that is 2mm.
Has anyone drilled out a standard set to make them flow like the turbo's? |
The 993tt squirters are 2 mm, but they are longer and stick way into the oil galley. I used them in my current build.
If I had to do it over, I'd see about using a pair of regular short 1 mm squirters like the latest RSR cases. t |
| All times are GMT -8. The time now is 08:29 AM. |
