-   -   Cam Rust Removal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/592411-cam-rust-removal.html)
kupcar 02-17-2011 08:30 PM
Cam Rust Removal
Hi Guys, I have a set of cams that I keep as spares that have developed some surface rust due to condensation. What is the best way to clean these up before a store them in oil bags. Thanks, Jeff
faverymi 02-18-2011 03:41 AM
I would use scotch guard pads until you see the machining lines or the wear lines clean.
Then bag.
kupcar 02-18-2011 07:41 AM
I guess Scotch Guard would work. I just want to make sure I'm not too aggressive with the cleaning. Maybe soak them in PB Blaster first to loosen things up? Thanks, Jeff
