-   -   mild upgrade to a 76 2.7 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/592753-mild-upgrade-76-2-7-a.html)
tassie targa 76 02-19-2011 10:06 PM
ok guys let loose
shortley i will be removing my 2.7 while i undertake a full respray and while its out
i would like to tweek it up a bit
it already has a head bolt upgrade, 11 blade fan, oil cooler, hydraulic tensioners.
and runs fine starts easy.
im thinking rings and bearing kit, ignitor 2, MSA, and new coil.
then what mild cam?
what about fuel is the mechanical fuel injection ok
i only want a sweet street ride for me and the wife
regards Michaelhttp://forums.pelicanparts.com/uploa...1298181924.jpg
E Sully 02-20-2011 04:29 PM
The cis injection is a good system when set up properly. It will limit your choices as to which cam you can run. I'm sure one of the experts will be able to help you with that. I would wait till it is apart and see if the pistons and cylinders are in spec before I decided on changes. Do you know the mileage on the engine, and any other work other than the head bolts?
tassie targa 76 02-20-2011 08:19 PM
best guess on milage is under 100,000kms 60,000miles based on discussion with previous owner
i will be doing some serious checking of current stuff before any decision but the motor feels good no smoke runs smooth but havent done a compression or leakdown yet
i guess im hoping that the big ticket items are ok
E Sully 02-23-2011 02:17 PM
Here are some posts about different cams.
http://forums.pelicanparts.com/porsche-911-technical-forum/547593-sc-cams-2-7s-observation.html
http://forums.pelicanparts.com/porsche-911-technical-forum/523569-s-cams-stock-pistons-2-7s-911-a.html
http://forums.pelicanparts.com/porsche-911-technical-forum/469474-sc-cams-2-7-a.html
