Camshaft identification
I recently bought a 1972 911E Coupe, with camshafts installed with "SE" markings in the front.
It is an MFI engine, 1973, unknown pistons-cylinders. The valve overlap is adjusted to 50, there are solid chain tensioners installed. Please identify those cams. Thanks, Harold |
Harold,
I tore down my 2.4 E (1973) motor to find it has 2.2S P&Cs and the S/SE cams. A few pelicans told me both cams were 911S and the SE was for both the S and E motor. Here are my two: http://forums.pelicanparts.com/uploa...1298783146.jpg http://forums.pelicanparts.com/uploa...1298783159.jpg http://forums.pelicanparts.com/uploa...1298783174.jpg I still have the 2.4T MFI system in the basement.... Hope the Florida weather is better than Marylands. Scott |
Cams
Scott, those are the same I have.
so the overlap is OK, the problem wit 2000-3000 RPM missing is then somewhere else. The MFI number is 13= 911T but it lucks rebuild. Maybe to S specs too. I did one day of adjustments, it is better now but still there. Thanks, Harold |
| All times are GMT -8. The time now is 04:42 PM. |
