-   -   my 2.0 E rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/594953-my-2-0-e-rebuild.html)
thor 03-04-2011 12:53 AM
my 2.0 E rebuild
hello,
finally some picture of my engine rebuild. I have decided to upgrade it to S engine.
Only MFI is missing (i got it but no yet mounted:p )
and SSI heat exchanger :cool:
Some details :
when i bought the car (coming from US ) this engine was with carburettors.
I rebuild it with MFI .
Casing was machined for intermediate shaft bearing mod , oil bypass.
Crank, flywheel (lighter ) and rods were balanced despite it is originally very good.
new oil pump from 3.2 and new intermediate shaft
993 studs
new pistons and cylinder (9.8 compression ratio)
heads machined and polished
2.0 s MFI pump rebuilt by bosch classic
S camshaft
new injectors
new microswitch, transducer ....
all sprocket, tensioner , nuts and bolts have been renewed.
clutch is a sachs performance for 215 MM
I must sand blast the fan as soon as the motorola alternator will be refurbished to achieve the job.
thanks to the great guy who have done this job.
jd
http://forums.pelicanparts.com/uploa...1299228551.jpg
http://forums.pelicanparts.com/uploa...1299228577.jpg
http://forums.pelicanparts.com/uploa...1299228595.jpg
http://forums.pelicanparts.com/uploa...1299228611.jpg
In a near future i will add a mandatory front oil cooler.
SorenDK 03-04-2011 03:52 AM
Wow looks great Jerome.... and I can actually see "my" breather cover sticking up there... :-)
One thing... why go from E cams to S cams... are you planning on using it for tracks?
thor 03-04-2011 04:37 AM
hi soren
yes for sure there is your breather cover :)
no not on track , but i wanted to have an engine character a bit different perfectly linked with my 2.0 S mfi pump .
I know it is not really 100% original but i wanted to have more pleasure regarding power.
Flieger 03-04-2011 10:59 AM
Looks great. :)
philippeF 03-08-2011 12:07 AM
Hello Thor.
Who did the job in Belgium ?
best
Philippe
thor 06-23-2014 03:11 AM
A very nice and well known mechanic in the area of Huy..... :D
thor 06-23-2014 03:15 AM
http://forums.pelicanparts.com/uploa...1403518532.jpg
