Wrist pin play
I have one pin that slides more easily then the others through the rod bushing and there seems to be a small amount of play also. could this be the cause of a slight knocking sound in that cylinder?
Is there a tolerance measurement for the pin and bushing? |
1980 SC22.020-22.033 mm inside diamiter of bushing. Clearance to pin .020 to .037.
Thank you!
| All times are GMT -8. The time now is 04:40 PM. |
