-   -   connecting MSD 6AL to one-wire '87 930 distributor? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/598850-connecting-msd-6al-one-wire-87-930-distributor.html)
laughac 03-24-2011 10:28 AM
I'm changing engines and lost the paperwork for my MSD box.
Does anyone have instructions for connecting MSD 6AL to one-wire '87 930 distributor?
Steve@Rennsport 03-24-2011 12:46 PM
Send me a direct e-mail and I'll shoot you the instructions.
laughac 03-24-2011 06:09 PM
Hi Steve,
I'm at Chris@Laughary.com
Henry Schmidt 03-24-2011 06:36 PM
http://forums.pelicanparts.com/uploa...1301016920.jpg
http://forums.pelicanparts.com/uploa...1301016941.jpg
laughac 03-24-2011 07:30 PM
Oh boy, I seem to only have one wire into my 3.3 disty.
I'll post a pic soon.
Thanks much!
Steve@Rennsport 03-25-2011 12:38 AM
Thanks much!
You have two, its a coaxial cable: a center conductor surrounded by a braided shield.
JFairman 03-25-2011 08:43 AM
If you have the distributor coax wire polarity wrong at the MSD CD box the timing will be advanced quite a bit because the trigger signal from the distributor is a square wave and from what I've read the MSD is triggered at the end of the square wave when the squared off slope falls.
If you've seen a picture of the distributor's square wave from an oscilloscope or computer monitor it's easier to see that.
Both polarities will run the motor but the wrong polarity will usually make it idle higher because the timing is being advanced and that will very likely hurt the motor if you get into boost with it like that.
Two Rivers 03-25-2011 04:38 PM
I thought it was AC voltage coming out of the dist. If thats the case what would it matter what wire went to what wire. Also isn`t the coaxial wire there just for RF interference.
Eagledriver 03-25-2011 08:38 PM
I don't know about the 930, but the SC dizzy output is voltage ramp up (or down depending on polarity) followed by a rapid voltage reversal and another ramp down. The trigger is meant to be on the rapid voltage reversal. If you hook up the wires backward the MSD will trigger on the ramp instead of the reversal. This will be about 30 degrees too soon and is very ambiguous because it's not a steep ramp.
-Andy
