-   -   Need scrapped on engine oil cooler (http://forums.pelicanparts.com/911-engine-rebuilding-forum/599298-need-scrapped-engine-oil-cooler.html)
neilca 03-26-2011 01:55 PM
I am looking for a scrapped on engine oil cooler. I intend to cut the cooler part off and use the base plate as a tool to fabricate an oil console with a filter. I will pay shipping to 30062.
I know the 993 console can be used but it doesn't meet my needs.
Thanks,
neilca
mskala 03-26-2011 02:32 PM
These guys have 2 different solutions also
Smart Racing Products catalog
http://forums.pelicanparts.com/uploa...1301175126.jpg
neilca 03-26-2011 03:32 PM
Thanks but that is not what I need.
tadd 03-26-2011 05:51 PM
Have you considered the one from iSystems?
It has some nice advantages like no turns, temperature port at the inlet so you know what your coolers doing and the internal ports are the same size as the case.... Unlike the 930/993 unit. Best is that it comes with the inlet.
Untitled Document
t
LJ851 03-26-2011 05:55 PM
Ive got one AND i'm local . I'll send you a PM.
turbobrat930 03-26-2011 06:02 PM
Untitled Document
t
Tadd, more info on those parts from Isystems.... The website doesnt have anything but a pic....
Looks like a very good alternative..... Thanks for posting!!!!!
neilca 03-27-2011 05:55 AM
That is an interesting setup. I wouldn't trust the upper two bolts to hold against the pressure. That is a big torque arm.
I intend to machine one myself that will place the filter at 45degrees toward the transmission. This should give me room to use a FL1A Motorcraft filter. I will also include the -16AN fitting for the pump inlet.
I could layout the hole patterns but it is just quicker and less mistake prone to back drill from an existing cooler.
