-   -   Help Identify this piston/cylinder set (http://forums.pelicanparts.com/911-engine-rebuilding-forum/601805-help-identify-piston-cylinder-set.html)
cymeryss 04-08-2011 10:54 AM
I came into a possession of a set of 911 piston/cylinders and was wondering if somebody could help me verify and price them. By the part # on the mahle box (930 103 990 01) they are for a 911 3.2l engine. That's great but I would like to make sure that what's in the box is corresponding to what is written! By the looks of them they don't look new, but well cleaned (nice cross hatch on the cylinders) and the rings look new. Could anybody provide any input to me on their condition by looking at the photos....I will need to verify that the cylinder bore is within tolerance, does anybody have the tolerance #'s? Thanks.
<a href="http://photobucket.com" target="_blank"><img src="http://i40.photobucket.com/albums/e218/cymeryss/Parts/P1050075-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i40.photobucket.com/albums/e218/cymeryss/Parts/P1050076-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i40.photobucket.com/albums/e218/cymeryss/Parts/P1050081.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i40.photobucket.com/albums/e218/cymeryss/Parts/P1050078.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i40.photobucket.com/albums/e218/cymeryss/Parts/P1050079.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i40.photobucket.com/albums/e218/cymeryss/Parts/P1050077-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i40.photobucket.com/albums/e218/cymeryss/Parts/P1050080.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i40.photobucket.com/albums/e218/cymeryss/Parts/P1050082.jpg" border="0" alt="Photobucket"></a>
Flat6pac 04-08-2011 12:12 PM
More than anything you need the number inside the piston. They are 3.2 and the maker should be Mahle, the number inside the piston should be 95P36 ++ or maybe no +s
Bruce
cymeryss 04-08-2011 09:17 PM
Yes I checked they are all Mahle 95P36++. I have a 1980 SC 3.0 so I don't have much use for them unless I could use them to upgrade to 3.2, but not sure what else would be required. Any ideas on how much I could sell them for?? Thank you for any info..
tom1394racing 04-09-2011 03:36 AM
These are the Mahle Nikasil 3.2 set. They appear to be in very good condition.
They can be either the 9.5 CR version or the Euro 10.3 CR version
Here's how to tell the difference
http://forums.pelicanparts.com/911-engine-rebuilding-forum/363526-these-euro-3-2-pistons.html
Here are the factory rebuild specs with some example data for the 3.2 pistons and cylinders
http://forums.pelicanparts.com/uploa...1302345322.jpg
cymeryss 04-09-2011 08:23 AM
That is great info Tom, thank you very much.....
It looks like you are measuring the piston diameter in two spots (D1 and D2) and the cylinders in four spots.....By your spreadsheet it looks like the values that I would have to meet are the cylinder wear limit and P to C Clarence, which makes sense.
My calipers arms are too short to get a good measurement on the height of the pistons, so will have to find a facility that can do that for me... THANKS.
tom1394racing 04-09-2011 07:34 PM
The other key measurement on the pistons is the ring lands. The top ring land sees the most wear and should be measured with shim stock or a feeler gauge.
The side clearance with a new ring installed should not be greater than 0.2mm
cymeryss 04-09-2011 09:52 PM
Perfect, that is more great info.....you are a really big addition to this site....regards,
JJ 911SC 02-03-2020 01:09 PM
Piston ID Needed
I know, old thread but no luck on my original thread
Originally Posted by JJ 911SC (Post 10739828)
E Sully 02-04-2020 03:50 PM
Here is a chart I found, don't see yours listed for Porsche.
http://forums.pelicanparts.com/uploa...1580860104.jpg
JJ 911SC 02-04-2020 03:56 PM
Thanks Ed,
It came in a Porsche parts lot but even if its not, very strange that google returns nothing.
I check some Mahle sites and nowhere to be found...
faapgar 02-04-2020 04:33 PM
piston
Looks like a slant ramp Max Moritz piston with relief in the middle.Maybe 9.5 -10 to 1.May be a 97mm 0n a 95mm base.Ciao Fred
