-   -   Replacing Oil Cooler after eng . failure (http://forums.pelicanparts.com/911-engine-rebuilding-forum/604716-replacing-oil-cooler-after-eng-failure.html)
pdonnelly 04-24-2011 07:29 AM
I dropped a valve in my race motor and put a hole in a piston. OUch. Should I replace the oil cooler in the process of the rebuild to be certain nothing is released from it after the rebuild?
ratpiper71T 04-24-2011 08:50 AM
I'm probably the least qualifies to answer here, but I'm gonna go with 'yes' actually 'hell yes'. You should have everything oil related flushed out and cleaned by professionals. My fear with the oil cooler is with radiator type coolers there are very small passages that could still maintains small metal debris, and of course maybe they'll only dislodge at the least convenient moment after you hav everything together and run in.
304065 04-24-2011 08:54 AM
Either replace or send it to Pacific Oil Cooler www.oilcoolers.com for cleaning.
MBruns 04-24-2011 10:38 AM
coolers
If you have enough cooler in the car replace the engine cooler with the spin on filter, if not replace the cooler, not worth the risk, with front coolers post failure and proper cleaning you can put a filter to catch debris but not on the engine unit it goes right to the bearings.
Mike Bruns JBRacing.com
pdonnelly 04-26-2011 09:03 AM
Oil cooler
Thanks folks for your thoughts. Got a new cooler coming.
AlfonsoR 04-28-2011 01:14 PM
304065, Thanks for the tip on Pacific Oil Cooler.
ChrisBennet 05-04-2011 05:39 PM
It's not just the oil coolers you have to clean, you really should clean every part of the oil system to get any bits in the crevices of the oil line fittings and external thermostat.
Pacific oil cooler uses an ultrasonic cleaning process. They are FAA certified also.
