kugelfischer's Avatar
2.5L ST Engine Build Questions
OK, so this is going to be the first of probably many stupid questions, but here goes.
I'm going to start pulling together parts to build my dream engine and I need some input or references to use. I am planning on a 2.5L S/T, twin plug, high-butterfly setup. I expect it will take me a few years to pull everything together, and would like to start searching for a good case.
I don't need a period correct case, I want something that will have a long life and work with the 86.7mm (2.5L) P/Cs
Do I go with a 7R, or something else? Would the choice be any different if I decided to go with a 2.3L?
K
Old 05-09-2011, 04:48 PM
304065's Avatar
Yes get a 7R if you want the mag case
86.7x 70.4 gets you 2493cc, sure that's what the factory did to get it under the limit, but why not 90 or even bigger, with a shorter stroke? You have a blank canvas and the time to get it right.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-09-2011, 04:56 PM
Case
Being that you have a choice, I would start with an alum. 2.0 case, they have more strength than you will need, the mag cases are a bit lighter but take so much effort/money to prep. and then they still have issues, after the last few full house 2.5 engines that had case failures I just won't start a small bore project with a mag case.
My .02, Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 05-09-2011, 06:27 PM
Thanks for the advice. I'd like to avoid the Mag case issues altogether.. I already have enough of those with other engines.
Would there be any reason I couldn't go with a 3.0L Turbo (Al) case, 90mm cylinders and say a crank from a 2.2l for the shorter stroke?
Old 05-10-2011, 10:16 AM
With custom cylinders to make your displacement, thats a VERY good way to go.
You'll need to spend some money on those heads to make the power you want.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-10-2011, 10:37 AM
356RS's Avatar
Great case, but then you might as well use the larger spigot bore of the 3.0 case and go with a set of 95mm pistons. You will also need the 3.0SC heads. So your in the 2.8SS area now.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-10-2011, 12:28 PM
