Leaky Engine Oil Cooler - Who can rebuild it?
I have a leaking engine oil cooler. I also have the engine out right now and have easy access to remove it and send it out for repair.
so who does this kinda work? |
It s cheaper to replace. I havent heard of anyone working on them other than to clean them.
Any of them I have, I ve tested for air pressure over a couple days. Bruce |
So you haven't removed it and tested it?
How can you be sure it's leaking? I bought a used (cleaned and tested) one from tom1394racing shoot him a PM. |
Pacific Oil Cooler, they do a great job.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/345812-oil-cooler-rebuilt-pacific-oil-cooler.html |
Pacific Oil Cooler. Just had two done for an early type, with some mount repairs, testing and plating it cost $175 for each cooler. Remember that Pacific Oil Cooler does work for Aircraft. The work is top grade. Highly recommended.
| All times are GMT -8. The time now is 06:12 AM. |
