-   -   All cranks use same bearings? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/607988-all-cranks-use-same-bearings.html)
txhokie4life 05-11-2011 07:27 AM
I acquired an RSR replica which has a 3.8L engine.
The engine appears to have spun a bearing and I'm doing some
preliminary homework on my options.
I know my M96 engines, this is my first aircooled foray.
From reading -- All things being equal the preferred crankshaft is a GT3 form a 997.
Do all the crankshafts 964/993/GT3 use the same bearings?
As ironic as this may sound -- I'm trying to be cost sensitive and
it would not make much sense to save $50 on a crankshaft only
to lock me into bearings that are super exclusive and cost me a small fortune.
Hope to crack the case this weekend and dive in.
thanks for you help,
Mike
MBruns 05-11-2011 07:32 AM
bearings
The mains are the same, all three rod brg.s are different.
Mike Bruns JBRacing.com
txhokie4life 05-11-2011 08:33 AM
Well it turns out there aren't any new 997 GT3 cranks available.
On back order -- could be months!
Recommended Alternatives?
m
