Aluminium Fan Centre
I have been looking at the Aluminium Fan Centre Kits that Supertec sell on EBay and they look quite good.
PORSCHE ALTERNATOR FAN CENTER KIT L W ALUMINUM PULLEY | eBay
Has anyone fitted one of these parts? If so did you re-balance the unit after assembly?
Looking at the inside of the fan it seems that there are 'balancing' holes drilled into the casting and I was interested to know if changing the centre caused any problems.
Old 05-16-2011, 11:04 PM
Assuming Henry will see this post I have one question. Is this a repair for a bad hub on a fan or is this for race engines that see high RMP's?
Old 05-17-2011, 08:20 AM
I just want to dress up the fan but the engine should be making around 7500rpm.
I sent the question to Supertec via EBay but haven't had an answer hence this post.
Old 05-17-2011, 08:28 AM
AlfonsoR's Avatar
Henry,
according to the e-bay application tool, this will not work for an 89 Carrera 3.2 ?
Old 05-17-2011, 12:56 PM
