Valve lift cam timing specs for M96.70?
Does anyone know where I can locate cam lift timing specs for a 996 Turbo M96.70 engine, or know of someone I could possibly contact at PCNA that might be able to assist in the matter? I know they exist for the GT3, but those cams specs are a bit different than the turbo.
Some may recall that my shop had multiple $K's in factory tooling stolen(amongst other things) that I unfortunately never got replaced to poor insurance coverage on shop tooling (:mad:) Tool 9661 was one of these tools and is now over $2500 to buy. Baums tool is a joke and still costs $1800+ to get from them. I'd like to CNC my own tooling again but could use the cam specs to time a "junker" motor here first. Can anyone help or direct me to the proper person who can? :( Big thanks folks! -Adam |
I have the casmshaft data and I will get you the info monday when I return to the shop.
P.S. if I forget please remind me regards |
Greatly appreciated, I will do that :)
Here you go this is directly from Porsche
Inlet opens @ 10 BTDC Closes @ 20 ABDC Exh opens @ 41 BBDC Closes @ 9 BTDC bear in mind that this is taken a 1mm lift and that the Vario mechanism would be in the fully adavanced position which according to these numbers would be 95 C/L intake and 106 exh regards |
Big thanks for the info, that's exactly what I was looking for!
Hey there... Any chance you might be able to help me with the same info for my 2004 996 GT3?
let me root around some I have changed computers and have not re installed the program
regards |
Hi racing97,
Were you ever able to dig up the 2004 GT3 timing info? Many thanks for your help, Tim |
Same as #4 posting
regards |
Awesome, thanks for the quick response!
| All times are GMT -8. The time now is 01:29 AM. |
