-   -   Crankcase casting (http://forums.pelicanparts.com/911-engine-rebuilding-forum/610151-crankcase-casting.html)
pirin911 05-23-2011 03:28 AM
Crankcase casting
Starting to clean the half that goes in the stand and found in the oil residue a piece that appear to came from these area.
http://forums.pelicanparts.com/uploa...1306146318.jpg
Can I clean with a grinder and put some JB Weld or leave it as is?
Here is another shot from the thermostat area showing some pitting of the aluminum.
http://forums.pelicanparts.com/uploa...1306146437.jpg
What do you think? Any help will be greatly appreciated. Thanks in advance,
Francisco
Flat6pac 05-23-2011 05:44 AM
The first pic is steel pressed in to the aluminum, all cases are like that.
The oil passage doesnt have to be finished, its just a drill. Aluminum is more resilient than magnesium, I would leave it be. You have to ask yourself, what would be the down side of building this?
Bruce
pirin911 05-23-2011 06:31 AM
Thanks Bruce.
Was thinking the same.
