Oil Pump Stud Stripped
I'm putting together my 2.7 case as part of a rebuild. In the process of tightening the three oil pump nuts to 25 Nm, I hear a "pop" on the third bolt. Now the stud does not support any torque and I've consequently removed it (along with the case threads) from the case. What are my options now?
- Can I install a timesert/casesaver myself (I don't see a 8 x 1.25 casesaver in the Pelican catalog)? - Assuming I can get one and I can install it myself, I also would guess this would require an expensive tool (Pelican lists a timesert installation kit for $169.99). - Plan B: Any good shop in/near the Riverside area? Or does this have to be done at a machine shop (Ollies did the cases and already installed casesavers for all the head studs and a few other susceptible studs). Thanks! Dave ![]()
Dave '75 911s Coupe |
I have a stainless insert that works very well, drill to size and its self tapping. I ll post a picture tomorrow when I am in the garage.
Bruce |
pulled threads
You can put a time cert repair in there, but it may be a clue to a bigger issue with older mag cases, yes its possible that someone over tightened it but may just be rotten, test a few other areas for normal torque and see what happens, I have assembled these engines and had critical studs pull even the case savers because the parent material is just old and tired.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Bruce - I'll look forward to pictures and more info on that stainless insert.
Mike - The issue with rotten cases is good to know when dealing with these magnesium units, however; I had a lot of machining work performed recently by Ollies. I would hope if my case was rotten, they would have mentioned something! With all of the money I have already invested in this case, I hope you're wrong in this instance. Dave
I have no interest in the company, but the inserts are easy to install and work well. Google the web site for a number. I purchased from a company in Fredericksburg, Va but no longer have their info.
Bruce ![]() ![]() |
M8x1.25 time-serts are much less than $100. A whole kit is like $50.
'66 911 #304065 Irischgruen Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) |
thread repair
Dave for that repair the kit above looks like it will work fine, I hope for your sake its an isolated issue, with Ollies doing all the other work I would say someone just over torqued that stud.
Regards, Mike Bruns
Check with McMaster-Carr, they have several types of inserts.
Bob
Bob Hutson |
Using input from the collective reply of all of you, I located the following product:
E-Z Lok M8-1.25 Stainless Insert for Metal - 453-8 ![]() It says "Easy to Use Solution For Repairing Damaged Threads in Metal. Install With Standard Drill & Tap; NO Special Tools Needed. Corrosion Resistant. Ideal For Soft Metals Like Aluminum, Cast Iron, or Magnesium." I'll check with my local hardware store tomorrow (McFadden-Dale Industrial Hardware - they're fantastic). If they don't have it, I'll jump on the internet and work on something else during the delay. Thanks to all for your input! Dave
abit off center
If that does not work I have 8x1.25 casesavers if you need some. the OD is 12x1.50
Another option if there is not a lot of thickness to work with you can install an oversize stud 10x1.50 on the case side. ![]()
______________________ Craig G2Performanceshop.com Twinplug and head work, casesavers, rockers arms, etc. Last edited by cgarr; 06-05-2011 at 06:43 PM.. |
