-   -   Assembling ConRods on Crank (http://forums.pelicanparts.com/911-engine-rebuilding-forum/613775-assembling-conrods-crank.html)
930LDR 06-13-2011 10:29 AM
Quick question. How 'freely' should I expect the conrods to rotate under their own weight once torqued down onto the crank? I completed the assembly over the weekend and as I rotate the crank each rod falls in a very smooth motion under its own weight, without any one moving more quickly or slower than another. The motion though is a reasonably slow one. Wasn't sure if I should have expected these things to spin around the crank fast or slow.
I know its a tough question to answer without seeing the real deal but am curious to see what you all may have to offer.
Thanks,
MBruns 06-13-2011 10:33 AM
rods
What did you use for assembly lube, and how much clear., grease will act much tighter than say 30 wt.
Mike Bruns JBRacing.com
930LDR 06-13-2011 10:36 AM
I used Lubro Moly 3010 (blue tube) - came with the super rebuild kit I purchased from our host.. Applied 'generously' as referenced in Wayne's textbook
Tippy 06-13-2011 11:36 AM
Sounds like mine
mike911996 06-13-2011 01:20 PM
did you also lube the sides of the rods by the big end as per the dempsey book pg 123?
930LDR 06-13-2011 04:15 PM
yes
Cipotifoso 06-13-2011 07:36 PM
Sounds appropriate to me. I recently installed rods onto a crankshaft (everything freshly machined) and all the rods fall in a fairly slow, smooth damped motion (from the assembly lube).
Dave
930LDR 06-13-2011 09:22 PM
Sounds good... the assembly lube was definitely thicker than I would have expected.
