-   -   Crankshafts 2.4, 2.7 and 3.0 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/614975-crankshafts-2-4-2-7-3-0-a.html)
jamesjedi 06-20-2011 09:31 AM
After reading a post that mentioned the 2.4, 2.7 and 3.0 crankshafts are all the same, I was hoping to see if it anyone could confirm this? Also, is there a difference between Euro and USA cranks? I ask this because I will need a std/std.
As always...THANKS!
lindy 911 06-20-2011 09:53 AM
They are not the same.
jamesjedi 06-20-2011 10:00 AM
Thanks for the reply.
James
Flat6pac 06-20-2011 10:11 AM
The 2.4, 2.7 .and 3.0 crank and rods are all the same for the 76 and 77 run of engines including the 3.0 Carrera of 76/77.
The 3.0 changed in 1978 to a 9 bolt flywheel and a different thickness rod.
Bruce
jamesjedi 06-20-2011 10:14 AM
Got it. Thanks. No now it makes sense.
James
