-   -   Shroud grommet (http://forums.pelicanparts.com/911-engine-rebuilding-forum/616229-shroud-grommet.html)
offyman 06-27-2011 09:17 AM
Shroud grommet
Has anyone come up with a substitute grommet for the wire harness hole in the shroud?
Darren at Pelican says the originals are not available separate from the harness.
Lee Mullin
Titusville,FL
304065 06-27-2011 11:02 AM
I think they are still available.
gamin 06-27-2011 02:22 PM
I believe I found a usable substitute at Lowes in the hardware section. They have some auto plugs and grommets and such in that section. Been a few years.
HawgRyder 06-27-2011 02:45 PM
For larger holes, I have used the stuff that ppl use on car door edges.
It looks like a closed "C" and comes in different colours.
You cut it to length and it just clamps on around the edge of the hole.
There will be a joint in it...but you can place that anywhere in the circle...so it cannot be seen.
Bob
fred cook 06-28-2011 04:06 AM
Grommet......
Go to your local NAPA auto parts store and see what they have. The store here is owned by a friend who lets me brouse thru the parts bins occasionaly. I found a grommet that was close enough to work on my engine that way. Good luck!
