Question about shaving heads
Warning Thread hijack!!!
I am rebuilding the top end on my SC using big port heads with .013 shaved off the bottom of the heads. Will I have a clearance problem? I know in Waynes book it says to check this clearance and adjust if nessecary. So how does one adjust this clearance? Thanks and sorry about the hijack! mg |
Using cylinder base gaskets you can make the difference if you have clearance problems.
Bruce |
| All times are GMT -8. The time now is 04:06 PM. |
