-   -   Installing Flywheel Seal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/618367-installing-flywheel-seal.html)
930LDR 07-09-2011 10:27 PM
Is it a better bet to install the flywheel seal when sealing up the case or waiting to install it once the case is together?
Thanks,
CaptainCalf 07-10-2011 04:08 AM
Thanks,
I've only done it once, but I did it while sealing the cases. IIRC I torqued the through bolts then installed the seal and after that I then torqued the perimeter bolts/nutsSmileWavy
RC
Flat6pac 07-10-2011 05:20 AM
I always install the seal when I put the halves together. Its much easier and you dont have to make the seal install.
I put the halves together and install perimeter nuts fiirst because the sealant is fresh.
Bruce
930LDR 07-10-2011 03:48 PM
Ended up installing while sealing the case. Went together fine. Nice and square. BTW I opted to install dry as most are now recommending around here.
