Oil Breather Seal
Hey guys... quick question. What's the consensus on the most appropriate method for installing the oil breather cover?
- Apply Locktite 574 to the seal?
- Apply Threebond 1211 to the seal?
- Use one of the above sealers but skip the actual seal?
Thanks,
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 07-16-2011, 03:28 PM
I put 574 on both sides of the seal.
Bruce
Old 07-16-2011, 05:45 PM
Thanks. Had seen a few others suggest that approach as well. Went with it.
Rob Montgomery
Old 07-18-2011, 07:18 AM
Dr J's Avatar
Now if we could only keep that oil breather hose from leaking...
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 07-18-2011, 04:30 PM
E-man930's Avatar
I used a light coat of Hylomar on both sides...
And you can keep the oil breather hose from leaking by replacing it with a thick silicone coupler and tightening the hell out of some quality .5" wide band stainless clamps.
Old 07-18-2011, 05:48 PM
