-   -   Deck Height yet again (http://forums.pelicanparts.com/911-engine-rebuilding-forum/620059-deck-height-yet-again.html)
mygatts57 07-18-2011 11:48 PM
I'm in the middle of a stock overhaul on my 2.2T engine and again unexpectedly baffled - this time over deck height. The Hynes manual says nothing about it. Wayne's book says .144 - .285 (his spec for "cylinder top outer diameter to cylinder head").Most posts talk about a minimum of 1.0 mm. That's quite a difference! What to do? :confused:
Steve@Rennsport 07-18-2011 11:57 PM
You really want 1.0mm.
CaptainCalf 07-19-2011 08:25 AM
I got 1mm on my 3.3 rebuild...bearly!
mygatts57 07-19-2011 10:07 AM
and ... another question
Thanks Steve. I'm having a heck of a time measuring from the extreme outside edge of the 2.2 T piston as the tip of my vernier is too wide. As far I as I can tell the reading is .6 mm with .75 mm of shims onboard. This way, I would have to use 3 shims - seems not right. Is there another way to measure other than the crush method? Can't do anything until the puzzle is solved. Thanks much.
Dave
Steve@Rennsport 07-19-2011 12:04 PM
JMHO,.....
The crushed-solder method is not an accurate nor reliable method of measuring deck height and not used by professional engine builders. To get accurate measurements of this very critical value, nobody else should use that either.
I use a dial indicator mounted to one of the head studs and 2 knurled screws made for this purpose to hold down the cylinder. This allows one to accurately measure the distance between the top of the cylinders and the "deck" around the perimeter of the piston domes.
elflamo 07-19-2011 01:28 PM
Dave, I have the exact same issue (posted in 'deck height in 2.4S'). What I was just thinking of is to file the tip of my vernier to the shape of the dome where it meets the cylinder wall. I guess that the best I can do
Dennis
cstreit 07-19-2011 02:06 PM
THat's where Steve's dial-indicator mothod can help. Small touch point, repeatable, simple.
mygatts57 07-19-2011 03:25 PM
Great idea. Thanks much. I'll do it! What was very confusing to me is why you would only measure the difference between the top of the piston at the outside perimeter and the top of the cylinder when some of the domes are so high? Probably not an issue with my lowly T pistons. So, I will do as Steve suggests. I'll report back. I assume I'm still looking for a min of 1.0 mm.
Thanks to all
304065 07-19-2011 06:07 PM
Distinguish between "Deck height" and "piston to cylinder head clearance." The two are only the same with a flat-top piston.
Deck height is the distance that the THEORETICAL flat top of a piston protrudes beyond the edge of the cylinder wall. In our engines it is negative and as Dr. Ing. Weiner says, you want it to be 1.0mm.
This is not the same as the distance between the top of the dome and the cylinder.
In order to measure deck, you must have a specification for the dome height of your piston. You can either get this from the piston manufacturer, or measure it as Bruce Anderson does in his book with a height gauge. Either way, if you use the bridge method or a dial indicator, you deduct the dome height from the measured height at TDC to get you the deck height. See below.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/422025-assembling-1966-901-05-engine-phase-ii-sealing-up-short-block.html
http://forums.pelicanparts.com/911-engine-rebuilding-forum/387496-setup-measuring-deck-height.html
mygatts57 07-20-2011 12:21 AM
An update. Thanks for the great information. I used a dial gauge set-up and started by finding absolute TDC. I then measured the diff between the piston top at the cylinder wall and top of the cylinder; the two ridges that will border the top sealing rings when installed. With a .25mm shim installed I got readings all over the map, all low and some even negative. I attribute some of this to a rather sloppy dial gauge setup and a dial gauge end that was very much on the bluntside. I will re-equip tomorrow and try it again. Just in case, I'm ordering some 1.0mm shims
Interesting that when I earlier tried the solder method result didn't in any way compress solder as thick as 2 mm. If my deck height is near zero, I would have expected some potential interference with the heads. Re: deck height only, there is no visible machining on the bases of the cylinders, so it must be the case?
Eagledriver 07-20-2011 01:00 PM
You should be able to tell by eyeball within 1mm. Certainly you can tell by looking if you have zero deck height. I've also used feeler blades to get an approximate value. For a street engine all you have to do is make sure you have at least 1mm and no more than 1.5mm.
-Andy
ajwans 03-04-2013 02:19 PM
I am a bit confused about this. Is this the piston edge to cylinder top measurement or the piston to head clearance?
I'm putting together a 2.0S and it seems I have tons of clearance above the piston dome, maybe as much as 4mm while the deck height is close to zero (but will increase with base gaskets.) I can't see how the factory would have ever got a 1mm deck height given the 0.25mm base gaskets I removed during disassembly.
The cylinder to head gaskets may add a little but if I understand correctly they should squish down to allow the cylinder top to meet the shoulder of the head dome adding no additional deck height. If otherwise, how is this additional deck height measured?
andy
Lapkritis 03-04-2013 04:42 PM
Deck Height is the space between the piston dome and the combustion chamber, at top dead center (TDC).
Lapkritis 03-04-2013 04:50 PM
And that cylinder to head gasket does add to the deck height and should be in there when you take your measurement.
crummasel 03-04-2013 05:11 PM
It does not.
Or how do you explain the markings of the cylinder on the cylinder head recessed surface?
ajwans 03-04-2013 05:13 PM
This is 2.0S, early design where the cylinder tops sit in a groove around the dome.
Here's a picture, the groove is red arrow and the gasket surface is the green arrow.
http://forums.pelicanparts.com/uploa...1362445978.jpg
andy
crummasel 03-04-2013 05:18 PM
Known and true.
But the thread owner was asking for a 2.2L with CE rings.
304065 03-04-2013 05:25 PM
No. Deck height is the difference between the theoretical deck of the piston and the top of the cylinder.
What you are describing is piston-to-cylinder clearance.
304065 03-04-2013 05:26 PM
Also incorrect. The 2,0 liter head gasket sits around the cylinder wall and does NOT add to deck height. It's there as a backup to the cylinder wall to head interface but does not compress.
Lapkritis 03-04-2013 06:03 PM
With all due respect, I disagree with your assessment.
"Competition Engineering - Easy Deck Height"
Your definition is different which makes you just as wrong as me in my opinion.
Lapkritis 03-04-2013 06:07 PM
Could you see any harm in including this if it does not impact the measurement on certain engines?
ajwans 03-05-2013 02:28 PM
So, getting back to my question. I can setup the deck height to find my desired compression so long as I maintain 1.0mm piston/head clearance?
n.b. I am using John Cramer's & Bruce Anderson's definition of deck height being the piston edge to cylinder top at TDC.
andy
304065 03-05-2013 07:46 PM
Walt is also wrong. He's a great machinist with a great reputation, but he is absolutely wrong when he uses the term "deck height" to describe, in great detail, the measurement of piston-to-cylinder clearance.
Suppose you and he are correct. Suppose you remove a cylinder head and use an angle grinder to remove material from the top of the piston. You have increased piston-to-cylinder head clearance, right? But you haven't altered the deck height in the slightest.
Take a look at the formula for calculating compression ratio. You can find it in Bruce Anderson's book, but it's a very common formula. Look at the deck height parameter and note how the overall compression ratio varies with deck height, which is a function of stroke, spigot height, cylinder height, rod length and compression height. Piston to cylinder head clearance has nothing to do with that calculation and is not used in calculating compression ratio.
Look at the definition of compression distance, this is defined as the distance between the centerline of the pin boss and the deck of the piston. It is not a function of dome height, or piston to cylinder clearance.
Hope that clears it up.
304065 03-05-2013 07:53 PM
I don't understand the question.
304065 03-05-2013 08:13 PM
andy
Andy,
Let's go back to your original question before this thread took a semantic turn.
Your 2,0 S pistons can be thought of in two pieces. A perfect cylinder, for the bottom piece, and a dome, on the top. If you were to take a bandsaw and cut the dome off, so that there was exactly 34mm of distance between the center of the pin bore and your cut, you would end up with a flat-top piston and then a dome. If you measure the volume of the dome, you can use that measurement in computing compression ratio.
Now, in practice this is not what we do. Some pistons, JE being a good example, actually have a flat ring around the outside of the piston top, to make it easier to measure deck height. You can actually set up a dial indicator on the edge of the cylinder, zero it out, then move the indicator over to this ring and measure deck directly. On a typical 911 engine, the deck is "positive" which is a bit misleading-- positive deck height is when the piston's theoretical deck is below the top of the cylinder.
This is the measurement that Steve is referring to when he says you want 1,0mm deck. This 1,0 mm deck is a good place to start, you don't want the piston sticking too far out of the hole, as you will end up with very high compression indeed AND will begin to impinge on a healthy piston-to-cylinder head clearance.
Interestingly, but not relevant, is the fact that 964 pistons actually have negative deck, they slide up into the head.
All right, how do you measure deck when you have a 2,0 Mahle piston? Look at the edge of the piston where the cylindrical wall stops and the dome begins-- it's just a smooth radius, there's no ledge to measure from! If you look in Bruce's book you will see a photo he took where he uses a height gauge and a test indicator to measure the distance between the height of the dome and a spot on the piston wall that is 34mm up from the center of the pin bore. (He probably subtracts half the diameter of the pin from 34mm and measures from the top edge of the pin bore.) Not perfect but it works.
A couple other points-- the 3,2 motor used a 32,8mm compression height- I guess they moved the pin up when they lengthened the stroke. Not a factor for you.
Also-- we think that Mahle used a ZERO deck to compute the stated compression ratios. This would make sense because deck height varies, so if you zero it out it gives you a reference for everyone's engine, and the actual static compression works out lower in practice. I credit Kenik with discovering this.
SO- to answer your original question- the factory achieved 1,0mm deck with normal crank, rods, spigots, spec cylinder height and 0,25mm base gaskets. S pistons have something like a 45cc dome, this is how they got to 9,8 to 1.
Hope this helps! Email me if you need the calcs.
Lapkritis 03-05-2013 08:18 PM
Re: Deck Height yet again
Let me make it simple: it couldn't hurt anyone to measure with it in there but it could hurt some if it wasn't.
ajwans 03-05-2013 08:25 PM
Thanks for the detailed response John, I cc'd my piston but only got 37.4cc for the volume of the dome. I did this by pressing a straight edge down on a piston until the very top of the crown was level with the cylinder walls.
Then I used the glass plate and burette to fill the void with 43.5cc of liquid. I must re-measure the dome height but my initial measurement of 16.1mm gave me a cylinder volume of 80.9cc.
Subtracting one from the other and I was left with a dome volume of 37.4cc.
I'll come back once I have double checked the dome height, perhaps an error here is why I am currently looking at <1mm deck height to get 9.8:1 compression.
andy
Lapkritis 03-05-2013 08:31 PM
Uh, wow. Piston design and chamber design specifically in CC volume certainly do impact compression significantly. Quench effect and ignition be dismissed, removing material from a piston and leaving other variables unchanged will decrease compression. This is common knowledge for anyone who works on an engine with carbon build up in the combustion chamber and knows about the pinging/detonation that results.
Piston to head and relation to deck height... who would seriously take a grinder to a piston?
304065 03-05-2013 08:38 PM
Andy,
80mm bore
66mm stroke
72cc combustion chamber (this was my '66, what is yours?)
With a 37.4cc dome volume, you end up with 9,4 to 1 with a 1,0mm deck height
To get to 9,8 to 1 compression you need a deck of 0.616mm
For reference, my JE slugs were 37cc dome for 9,5 to 1, but that was with a 1mm overbore to 81.
Here is my thread (from SIX years ago! :)) showing my pistons, see how the tops are flat? That is 37cc dome. Do yours look more like a 906, is there a sharp ridge on the top? That is a higher dome than mine. Look at the last photo in the thread-- those are 906 pistons I think, although some say that the 69S pistons were the same.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/368320-jugs-slugs-confessions-je-piston-owner.html
304065 03-06-2013 05:20 PM
Yes, you are right. And nobody here, including me, has said anything to the contrary.
Also correct and has nothing to do with the discussion of deck height.
Agreed.
I don't know anyone that would. The point of the example is to illustrate to you that you can change piston-to-cylinder clearance all you want, and you still haven't altered the relationship between the top of the cylinder wall and the position of the piston.
Look, the reason it's called "deck height" is that the term originated as the measurement of the distance between the centerline of the crankshaft and the "deck" or top of the cylinder block on a watercooled engine. If you look up the specifications for, for example, a watercooled V-8 Ford Windsor, you will find "deck height" of, for example, 9.480". Of course this is not the piston-to-head clearance.
In the Porsche world, we don't bother expressing it that way, but it's the same concept-- distance between the piston height excluding the dome and the top edge of the cylinder. This is a shorthand way of expressing it that gets the engine builder to the same place, rather than having to say "198mm deck height." Practically only machine shops will have a mandrel that goes in the main bearings to truly measure spigot height. Here is what that looks like (on a 356 motor):
http://www.precisionmatters.biz/imag..._installed.jpg
If you search here you will also find many other references as to why this is so. Take a 2,0 liter engine like Andy's-- 80x66 with a 130mm Rod and a 34mm compression height on the piston.
Half the stroke is 33mm
Rod length is 130mm
Compression height is 34mm (same for all 2,0-3,0 pistons)
This all adds up to 197mm, that is the height of the reciprocating mass without the piston dome. This is the "magic number."
For the cylinder side--
Spigot height 115.55
Base gasket height 0.25mm
Cylinder height 82.2mm
All adds up to 198mm. Subtract the height of the reciprocating mass from the height of the cylinder and you get 1.0mm deck height.
Another reason why we use this terminology is that it's pretty constant across years. If you look at the 2,4 motor, the stroke went to 70.4mm, the rod length dropped to 127.8, and the cylinder height was the same.
70.4 /2 = 35.2 plus 127.8 rod +34 compression distance = 197mm, the magic number.
Try it with a 3,2 motor-- 74.4mm stroke plus 127.0 rod length plus 32.8mm compression distance = 197mm. The magic number again.
Hope this helps, I can't explain it any more clearly.
Lapkritis 03-06-2013 06:28 PM
Re: Deck Height yet
You're doing a great job explaining to yourself so don't sell yourself short.
So if all things are equal and the primary concern is piston to head clearance...which is only changed by adjusting deck height... then it makes sense to use the only non-static metric which is the deck height. It's not hard to understand.
Cupcar 03-09-2013 08:39 AM
To add my BS here.
To me "deck height" is the difference between the plane of the piston's horizon line (the point of reflection from the piston's side to crown) and the top plane of the cylinder. This is a nice number to have for calculation of deck volume for CR number. I like Steve W's method for measurement of this however one must consider base gasket, if any, crush.
This may NOT be the point of closest interference between piston and head however, for example the piston crown may be close to the combustion chamber above the plane of deck height.
The important thing is that no point of potential interference between the piston and head should be less than .040" = 1 mm is what people say and seems time tested.
One has to look for these interference points when putting odd combinations of head and piston together, particularly with bore increases. For these points I use solder and a head assembly.
Having said that, I have "gotten away" with .035 (Carillo + Mahle forged) at a few points at the combustion chamber edge, but didn't like it.
ajwans 03-10-2013 03:48 AM
It turns out that using dome height 15.9mm, which I accurately measured using a genuine made in USSR height gauge.
My deck height without a base gasket installed is right about 0.018" or 0.45mm. Add the base gasket and I have 0.7mm deck height.
Based on this my compression is about 9.4:1, if I were able to offset bush the rods 0.5mm I'd get pretty close to bang on 10:1. Opinions?
This would make my deck height only 0.2mm but there's plenty of piston to head clearance.
andy
ajwans 03-16-2013 06:00 PM
I cut a perspex disc on the lathe to make a more accurate head volume measurement and got 71.2cc which brings my CR up to 9.7:1 without changing the deck height. I'm happy with that CR.
andy
