-   -   Denso 580 mounting options? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/622413-denso-580-mounting-options.html)
jonesb930 08-06-2011 08:37 PM
Post up some pictures! This is still one of my options as well.
ONQRACIng 08-07-2011 07:20 AM
Will do, after the season, we will begin the build.
ONQRACIng 10-11-2011 01:24 PM
Just got the GT3 crank, New R+R Rods, JE pistons, Clewett Pulley and flywheel back from my machinist. Paul Schwarz and I should be building this soon. The Denso mounts are done as well. We went with the option in the photo, clean and light.
Now I need to cut my Magnacore wires in half to may 12 COP wires, should be easy enough. Anyone know a source for the plug boots and denso plug wire connectors and 90deg boots?
~A
ONQRACIng 01-03-2013 12:17 PM
Just picked up the complete Patrick 580 setup....
Mount and Wires.
3.6 should be sweet this season..
jonesb930 01-15-2013 05:35 PM
post some pictures! I still need to choose a coil setup for my car.
Ken911 01-15-2013 06:27 PM
I bought Toyota (denso) coil on plugs so no plug wires at all and no mounting brackets.
jonesb930 01-16-2013 05:19 AM
Ken,
can you give me part numbers for those Toyota coils (or the OEM application they are from)?
Ken911 01-16-2013 05:40 AM
yeah i'll look at them when i get home from work tonight. and post the part numbers. they fit really well in 964 valve cover holes.
