Stroker 911 ; Rod Length : Stroke Ratio - Making the 911 Engine W I D E R
I have been thinking.
For the same efficiency (or VE), which is usually dictated by drivability requirements (see: "Why You Don't Want to Drive Race Engines in Traffic"), there are really only two ways to make more power: 1) Displacement or 2) Forced Induction Not getting into forced induction right now, let's talk about displacement. It's simple : Bore and Stroke and the number of cylinders. Our 911s have limits on how big we can make the cylinders before the walls get too thin. So we turn to 'Stroke'. As far as most engines are concerned, 911s are very oversquare (much bigger bore than stroke) and that generally makes an engine inclined to rev. If we try to lengthen the stroke, the rod length/stroke ratio can become a problem, because we have a fundamental maximum width that the engine can be. The 2.0/2.2: 130mm rod on a 66mm stroke = 130/66 = 1.97 2.4/2.7/3.0 : 127.8mm rod on a 70.4mm stroke = 1.815 3.2 : 127mm rod on a 74.4 stroke = 127/74.4 = 1.707 3.6 (Air-cooled) : 127mm rod on a 76.4 stroke = 127/76.4 = 1.662 GT3 (127.8, 130, 138mm rods) = 1.673, 1.702, 1.806 respectively As you can see if we tried to build a 3.6 with a RLSR (Rod Length:Stroke Ratio) like a 2.0L, we would have a 150.5mm rod, which would mean the engine would have to be about 2" wider (23.5mm on each side). Porsche seems to believe that its "Endurance" rod should be 138mm on a 76.4mm stroke, for what are believed to be wear/durability reasons. [RLSR's nearer to 1.5 induce much more piston side-loading and greater piston accelerations exacerbating wear.] Of course, the discussion about *WHICH* RLSR to use is more complicated than I am wondering right now, I am just curious, if we desired, say, a 1.7:1 RLSR and wanted a longer stroke, how much wider can we make the 911 engine, and what other issues would we run into? -Taller Cylinders -Spacers for the chain boxes -Longer chains -Modify the engine tin -What else? Do we have interference with the oil pump ? What is the maximum we can do here? And short of custom cranks, how far can we push a standard 964 or GT3 crank in terms of stroke? I think I have heard about 78.x mm but is that verified? Could we do more if we used smaller rod bearings? Right now, if 78mm is possible, with a 105mm cylinder (possible) you can make a 4.05L motor! But to get a 1.7 RLSR, we would need to widen 6.4mm on EACH side the engine to use a 132.6mm rod. Looking forward to your replies! |
As to the cranks, the limiting factor is the bore spacing that porsche used. Some guys have tried to overstoke but reliability ultimately falls short. |
Would that be the CMW 82mm Billet Crank? Are there others on the market?
Thanks Aaron |
I know of at least one 2.8 long stroke RSR motor (not factory RSR parts) which got a "better" RS ratio by just lengthening the rod. Had to section the plastic engine cover to extend it some, use thicker cylinder base spacers, make chain box spacers, longer chain (should be simple to do that) or shorter idler gear, and something to deal with the carburetor actuation system - maybe just lengthened the cross rod. Don't know what they did about head studs (this pre-Supertec).
There is a guy racing a 4.0 air cooled 911 motor. Works very well indeed, so that displacement can be achieved. |
The new DFI engines are much taller with the anticipation of more stroke in the future. I am not sure on the bore spacing. |
Jim Copp with the POC runs a 4.2 in his '71 racecar, if I remember correctly. It's got lots of trick parts, top secret of course.
We built a 4.0 using a GT3 crank and rods, 993 case 964 heads with titanium valve and NL Nickies.The engine ran 200hrs before it's first freshen up. The RPM was limited at 7400.
http://forums.pelicanparts.com/uploa...1312595203.jpg http://forums.pelicanparts.com/uploa...1312595507.jpg http://forums.pelicanparts.com/uploa...1312595268.jpg http://forums.pelicanparts.com/uploa...1312595303.jpg http://forums.pelicanparts.com/uploa...1312595375.jpg http://forums.pelicanparts.com/uploa...1312595419.jpg |
Henry
Why 964 heads instead of 993 heads? Because it is what the customer had? Did you use the 993 cam carriers? Those look like they are so much easier to work with when installing the rockers, plus they can't leak out past the shafts. |
Mostly parts availability.
Rods are really long btw. |
wider motor
When I have done this I get my parts from Peter Dawe at Dawes Motorsport.He has the spacers and different size idlers to make it happen.I use a 132mm rod on 66mm crank with no spacers.Just a different pin height for the piston for a 2.8.Fred
...I was thinking about calling Peter. My engine was just torn down. I believe Peter built it originally. Rods I believe are 139.8 mm. This is on a long stroke engine. |
[QUOTE=YTNUKLR;6177153]I have been thinking.
For the same efficiency (or VE), which is usually dictated by drivability requirements (see: "Why You Don't Want to Drive Race Engines in Traffic"), there are really only two ways to make more power: Read with interest. Agree to a point but not absolute. I am happy to give my opinions and share my experiences when solving a problem, but this is right in our wheel house and our core business. To offer up what we do in situations like this would be giving away our IP. However, I would suggest you don’t disregard working on your engine’s efficiency altogether. Looking at making your engine more efficient doesn’t necessarily mean you are going to make it non-street able. You will find that there is an amount of HP that can be influenced before adding displacement. Making sure every clearance is correct, every part is in spec and closer to the minimum tolerance, lowering engines friction with coatings and micro polishing, using lighter internal parts, lowering any forces that are often taken for granted, all very important in clawing back lost power in running your engine. Controlling the engine harmonics, so that the valve timing stays where it should through out the engines RPM range, making sure that each cylinder outputs the same torque number amongst many other areas that should be given attention. Give these some attention and you will be surprised how much added performance you will gain. Making some positive changes here will only help when you do add to the engine’s displacement. |
making it right
Neil is correct.The devil is in the details.Installed valve. the heigth should be the same.Valve spring height should be set.The pressure on the gauge for the installed heigtht of the spring should be equal.Ntow you are started. I just took apart 2 3.2 ENGINES and the outer spring is installed an average of 5 times upside down with the progressive outer spring upside down.To the point responding rockers had pitting at the top lift point .Be careful out there
On my case, we can make the "thickness" of the case...i.e. the dimension from the cylinder spigot face to the case parting line SIGNIFICANTLY thicker than stock. We have over 1/4" of material to play with here.
We did that because of two reasons: 1) to give us enough material to ensure true flatness and 2) for the eventual customer that would want way more stroke or lower compression for an insane turbo build. |
Faapgar - tell us more about installing valve springs upside down. The ones I have used -- stock, and Aase -- look symmetrical to me, and I don't recall anything in the Factory manual about this.
Who makes progressive springs? Where do you want them to be strongest - at peak so the rocker doesn't fly off of the cam? Or at closure, so the valve head doesn't bounce? |
Hi Walt, outer stock spring is progressive. Tighter coils are at the spring seat.
Springs
Walt,Aaron is correct.You have to look close.If it is not a machine shop that does many Porsche heads it can be easy to miss.When ever I take a motor apart I check the valve springs and look at the head nut washers to see if they are installed right side up to see if the motor has ever been apart before.It is just another little thing that a lot of people miss.Fred
To keep this discussion focused on 2.8s and Henry's work of art and so on, see new discussion: Progressive Valve Springs.
| All times are GMT -8. The time now is 11:12 AM. |
