-   -   Pressure fed tensioner collars, use em? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/624346-pressure-fed-tensioner-collars-use-em.html)
swade 08-12-2011 03:32 PM
I have read that the pressure fed chain tensioners can have a collar installed to prevent colapse in case of seal failure. I see that some of the engine builders use pressure fed tensioners, do you use these collars?
Thank you
cgarr 08-12-2011 03:38 PM
I use the internal stop upgrade, does pretty much the same thing.
E Sully 08-12-2011 03:47 PM
http://forums.pelicanparts.com/911-engine-rebuilding-forum/448877-oil-fed-tensioner-modification-add-spacer-survey.html
Turbo_pro 08-12-2011 04:32 PM
Use Chain Savers on all types of tensioners just for peace of mind.
The key to survival of all types of tensioners (mechanicals excluded) is to run wide tensioner arms.
Binding of the arms on the shaft is the primary reason for tensioner failure.
Our host sells the wide tensioners and Supertec manufactures a replacement if you have trouble locating the factory models from our host.
Supertec tensioner arms
http://forums.pelicanparts.com/uploa...1313191934.jpg
http://forums.pelicanparts.com/uploa...1313191961.jpg
motley911 08-12-2011 04:41 PM
I also used them in my build. Turned out of a piece of round bar stock.
http://forums.pelicanparts.com/uploa...1313192384.jpg
http://forums.pelicanparts.com/uploa...1313192442.jpg
Richard.
swade 08-12-2011 06:18 PM
Thanks folks, I had not heard of the internal stop.
w
