Will not start!
Trying to get my freshly rebuilt 85 carrera started.
Checked plug leads and spark, fuel pump and fuel pressure, throttle sensor switch. I get the occasional back fire, but that's all. Any one got any ideas?:confused: |
Distributor clocked correctly?
Plug wires in proper order? |
Check flywheel sensor, switch them around. The flywheel sensors are the same but send different info.
Bruce |
Checked the cam timing and plug leads several times.
Replaced the fuel pump in desperation. Switched the flywheel sensors around and it sounds worse. Replaced the throttle position switch. I can only hear one injector ticking, so have just pulled them all and sent them to be checked. I'm going away for a week tomorrow so I will have to wait to see if this works. Thankyou for the advice so far. Lee. |
How long was your engine apart?
It is not uncommon for injectors to stick closed after sitting for a few months. You can stimulate them with a short 12 volt burst from a secondary source. One more thought: The ground cluster on the left side of the manifold is easily overlooked. Just a thought |
| All times are GMT -8. The time now is 03:47 PM. |
