-   -   Dial Indicator Setup (Deck Height) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/625595-dial-indicator-setup-deck-height.html)
930LDR 08-19-2011 01:37 PM
I'm trying to figure out the best way to setup and use my dial indicator to measure deck height on my flat top 3.3L CIS pistons / Cylinders. Seems to me you would need to mount the indicator to allow you to set it at 0 when the piston is at top dead center and then measure then rotate it over to measure the span between that and the top of the cylinder but I can't imagine you'd retain any accuracy once you moved the mount.
Probably missing something very simple in my logic.
304065 08-19-2011 01:54 PM
Rob,
It's call the "Jo block" method or Gage block. (Hardly anyone calls them Johansen blocks anymore).
The procedure entails using a depth gauge base on your dial indicator, resting on a pair of identical gage blocks, which in turn rest on the edge of the cylinder.
  • The indicator, base and gage blocks are placed on a flat surface like a surface plate or piece of glass
  • The indicator is moved down so that there is slight preload on the tip (needle moves off zero) and then the screw holding the indicator is tightened
  • The gauge scale is turned to set zero opposite the indicator position
  • With the indicator zeroed, the entire stack is picked up and moved to the top of the cylinder. The gage blocks rest on the cylinder edge
  • Holding the stack tightly, the crank is rotated to bring the piston to TDC.
  • At TDC, the indicator point will be depressed and the indicator will read the sum of dome height and deck height. Subtract the dome height to get the deck height
Here is a photo of when I used this method to measure deck. Note that you need an indicator with a stroke greater than your anticipated dome height. A 25mm travel indicator would be fine.
http://forums.pelicanparts.com/uploa...1217119703.jpg
