Restoring a stock SC engine - please help on some brackets and clamps
Hello,
I would like to ask some help to this board in order to find the right location of some brackets and clamps from my SC 1982 engine. http://forums.pelicanparts.com/porsche-911-technical-forum/556994-yes-forward-but-different.html As I am trying to maintain the originality as much as it is possible, I would like to know the real location of some brackets/clamps, shown on the diagrams bellow - if someone has pictures of a real engine on the locations I am showing, that would be perfect: http://forums.pelicanparts.com/uploa...1314109245.jpg I would like to know where does the bracket 62A attaches. Can't figure out what is the bracket nš 40A - where does it attaches? Where is the bracket nš 26 attached and which hose goes through the clamp nš 27? http://forums.pelicanparts.com/uploa...1314109291.jpg I need to know where the nš 27 and nš 37 clamps do attach and which hoses pass through. http://forums.pelicanparts.com/uploa...1314109340.jpg Here the location is easy... I just don't figure out, which hose goes inside clamp nš 13 http://forums.pelicanparts.com/uploa...1314109381.jpg Regarding this image, I need to know how does the bracket nš 41 - where the two oil line pass trough - attaches to the engine. Thanks in advance to those that can help. Best Regards |
Alex
Here's some pics of a rebuilt '79 SC motor. Hope this helps http://forums.pelicanparts.com/uploa...1314178799.jpg http://forums.pelicanparts.com/uploa...1314178858.jpg http://forums.pelicanparts.com/uploa...1314178898.jpg http://forums.pelicanparts.com/uploa...1314178961.jpg http://forums.pelicanparts.com/uploa...1314179015.jpg |
Thanks Tom
Unfortunately this engine is not like mine. Mine is from 1982 and has some different details. For example, this doesn't have the black bracket that hold the two oil lines behind the air box. But thanks anyway for your help. It has been very difficult to find pictures of a stock engine like mine, specially when many people (for weight savings), remove some brackets and clamps. |
Here some pics of an '82 SC
http://forums.pelicanparts.com/uploa...1314188859.jpg http://forums.pelicanparts.com/uploa...1314188951.jpg |
Great! One issue is solved! Thanks a lot!
Tom,
Don't want to abuse on your help but, assuming those engines are close to you, would it be possible to show me a clear view of this point: http://forums.pelicanparts.com/uploa...1314199012.jpg I really can't figure out how this bracket attaches to the engine. A photo on a different perspective might help to solve this. Thanks a lot for your help. |
On my 82 sc that bracket attaches to the vibration damper bolt on the left lower portion of the airboxhttp://forums.pelicanparts.com/uploa...1314255476.jpg
Thanks Davy,
That was the picture that I needed. Although the rubber hose doesn't let us see, I beleive that the bottom part of the black bracket with the two rings is not attached to the engine at all, right - I think it touches the oil cooler?? |
| All times are GMT -8. The time now is 08:11 PM. |
