-   -   carrera tensioner (http://forums.pelicanparts.com/911-engine-rebuilding-forum/627225-carrera-tensioner.html)
brp914 08-29-2011 05:58 PM
carrera tensioner
While disassembling my 3.2 I was not able to compress the tensioner to insert the "grenade pin" before removing the tensioner, so it popped fully open. Does this harm it?
4sd911 08-29-2011 09:05 PM
That's how you remove them. When you install you'll need the use of a vice to compress and install the pin, slow pressure with the vice to compress.
dtw 08-30-2011 07:40 AM
No problem.
Walt Fricke 09-04-2011 04:31 PM
Sometimes you can use water pump pliers to compress the tensioner, before you remove it, just enough to insert the grenade pin. Saves having to put it in a vice.
The "pop" if you just pry the tensioner off is disturbing, but does not seem to hurt anything. At least it has not hurt mine.
