Carburetor question(s)
Do PMO carbs take IDA style main jets and air correctors? and......
are 40 PMO's the right choice for a high revving 2.8/2.9 motor or would the 46's be more appropriate. Thanks in advance for the feedback. Tom B. |
Jets are Webber type. I run 46 mm on a 3.0 with GE 60 cams. Your best choice will be determined by your setup. You need to share;
CR Cams Piston type Head Ignition system Fuel RPM range More info = better answers. |
PMO's take Weber IDA idle jets and IDF mains, A/C's, and emulsion tubes. 46's are the right ones for a high-revving engine of that size. Tune the power curve with main venturi sizing. |
| All times are GMT -8. The time now is 01:56 AM. |
