-   -   Can't figure out Intake Gasket part # (http://forums.pelicanparts.com/911-engine-rebuilding-forum/628783-cant-figure-out-intake-gasket-part.html)
txhokie4life 09-08-2011 07:56 AM
Finished my 964 long block.
Ready to put it in my track car.
Going to use the TWM Throttle Bodies.
They have an interposer which converts the 2 bolt oval pattern
to the 3 bolt cylinder heads.
Would love to get a link or a part #
thanks in advance!
Mike
http://forums.pelicanparts.com/uploa...1315493564.jpg
http://forums.pelicanparts.com/uploa...1315493707.jpg
http://forums.pelicanparts.com/uploa...1315493727.jpg
Henry Schmidt 09-08-2011 11:38 AM
thanks in advance!
Mike
<<<<<<<<<snip>>>>>>>>
I don't know the part number but I have a nice used set I'd be happy to sell.
These are huge (46'x 54mm) so I assume hey are for racing only.
http://forums.pelicanparts.com/uploa...1315506673.jpg
http://forums.pelicanparts.com/uploa...1315506689.jpg
MBruns 09-08-2011 11:57 AM
gaskets
If you need gaskets for the 3 bolt port call PMO they have them and the large 2 bolt as well
Mike Bruns
Henry Schmidt 09-08-2011 01:19 PM
Wow, getting old sucks.
I missed the part about the gaskets.http://forums.pelicanparts.com/uploa...1315513294.gif
txhokie4life 09-08-2011 03:39 PM
Okay -- took me a bit -- Now I know why I can't find a part.
The 964 engine donor (as opposed to the Throttle Body engine)
had the plastic intake manifold. The plastics seals (maybe with an oring)
to the 3 studs.
I might have to just make some gaskets with some gasket sheet material.
Was hoping to find it locally as I'd like to install the engine this weekend.
thx.
Mike
BoxxerSix 09-08-2011 05:19 PM
yes it's an o-ring on the 964/993 part number 993 110 713 01
Henry Schmidt 09-09-2011 09:03 AM
Just glue the intake adapter to the head using ThreeBond 1194.
It will seal and is relatively easy to remove later.
