-   -   A little advice needed on a 3.3 turbo engine. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/628879-little-advice-needed-3-3-turbo-engine.html)
Oheggem 09-08-2011 04:45 PM
I had some blue smoke when i had a buddy behind me so i did som investigating. Some oil coming into the turbo inlet and the turbo i think is ok.
This is how 5 cylinders look like.
ImageShack® - Online Photo and Video Hosting
This is center cylinder drivers side. #3?
I asked in 930 forum and got tips but hope someone here know or have seen this before.
Jump on it with tips of what to check please:)
Oheggem
BoxxerSix 09-08-2011 04:48 PM
Worn exhaust valve guides commonly lead to blown stem seals. Have you had a leakdown/comp test performed on the motor?
Oheggem 09-09-2011 03:36 AM
No i did not. I was hoping it was just a valve stem that is gone. If this seems to be either valve guide or stems then i think i`ll try changing the valve stem without taking out the engine as i have very limited space and hope that fixes it for now.
Got a bit worried about maby piston ring or similar.
CobraJet 09-09-2011 05:52 PM
Originally Posted by Oheggem (Post 6244746)
......If this seems to be either valve guide or stems then i think i`ll try changing the valve stem without taking out the engine .......
MMmmmmmmm??????
How does one go about doing this?
