-   -   piston pin really tight (http://forums.pelicanparts.com/911-engine-rebuilding-forum/629382-piston-pin-really-tight.html)
rockreid 09-12-2011 09:03 AM
I am rebuilding my 73.5 CIS 911 Targa and the OEM piston pins are not happy going into the OEM pistons. The pistons were cleaned at a machine shop and the pins are not happy trying to insert back into the pistons. Should I have to knock the pins in with some force with my plastic hammer or should they simply slide in?
CaptainCalf 09-12-2011 09:23 AM
You may want to check the edges of the pin bores in the pistons for burrs & check for any dirt/grit left in the pin bores from the machine shop.
Also, just in case you didn't try this already, put some oil or lube on the pins and in the pin holes to help them slid in with a little tapping with a rubber mallet.
HawgRyder 09-12-2011 10:20 AM
Keep the pins in the fridge overnight...they will slide in easier.
Bob
Eagledriver 09-12-2011 12:32 PM
Bob has the right idea, I heat the piston crowns with a propane torch. You only need to get the pistons hot enough to slip the pins in.
-Andy
