-   -   schematic question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/631350-schematic-question.html)
brp914 09-24-2011 10:40 AM
schematic question
In the Haynes schematic diagrams (which may be copied from factory manuals), a wire may be indicated as 4.0 RD. "RD" ofcourse means red, but what about the "4.0". I used to think it was about amperage, but now I wonder if it is cross section in mm2. Anybody know?
Flat6pac 09-24-2011 11:17 AM
Its the size of the wire.
Bruce
brp914 09-24-2011 11:41 AM
Thanks Bruce. By the way, I've got your motronic mounted on my engine and it's about to go in. Problem is, I've never seen a 3.2 in a 911 and my 911 is a '77. I'm confused about some of the vacuum and other air tubing. Hopefully you can help. I'll try to post some pics later in a separate thread.
Flat6pac 09-24-2011 02:40 PM
You ve got a PM and a phone number.
Bruce
nreed 09-24-2011 07:08 PM
Yes it is mm^2. See the following link for converting back and forth between awg and mm^2
Wire Gauge calculations
