Replacement cylinder height (delta) class
The specifications for the 2.2 liter motor say that cylinders come in two basic classes, 5 and 6. (What happened to 1 through 4?) There are different specifications for replacement cylinders in "R5" and "R6" classes, which I am guessing are intended as single replacements for an engine that still has 5, or fewer, of its original class 5 or class 6 cylinders. The specifications line up like this:
I am looking into this, because I have a single, new cylinder for a 2.2 E, marked class 5. The originals are class 6. Yet, when I mount two of the originals and the replacement class 5, I find that the class 5 cylinder is taller by over 0.05 mm. I take it that single cylinders, these days, come out of broken up piston/cylinder kits. I am guessing that the R5 and R6 classes have long been unavailable. |
I ve never seen an R class cylinder, only delta 5 or 6.
Bruce |
Have you measured the heights of your "original" class 6 cylinders to find if they have been machined previously and are now in a class 5 deck height range.
I have come across this in many of the motors I've rebuilt over the years, with mismatched cylinders machined to fit the remaining cylinders in the set. |
The Specs booklets refer to R cylinders as "replacements", the '72 workshop manual as "reconditioned". The difference appears to be .25mm, the size of one cylinder base gasket. Like Bruce, I don't recall ever seeing one. As Adam suggested, you should measure all your cylinder heights, preferably on a surface plate, and adjust them to match if necessary. http://forums.pelicanparts.com/uploa...1317012020.jpg |
I believe the "reconditioned " cylinder height refers to height targets for cylinders that are re-cut to true up either the upper or lower sealing surfaces during an overhaul.
Similar in concept to the undersize crank journal target sizes. |
Mixing different height classes in a given bank of cylinders can lead to inadequate clamping on the short cylinder and a leak at the cylinder to head interface.
Cylinder heights should be checked to make sure all cylinders are within the allowable height variation. |
The heads will mate to the cam towers with no problem and the cam will spin nicely.
You need to be more concerned with the cylinder to head interface. I have seen several cases where heights have been mixed with resultant leaks and ruined cylinders and heads. |
Thanks, Tom. Kind of hard to understand, with the heads being separately held by bigger fasteners, but those cam carriers are really rigid.
Are these numbers the same for 930 3.3 cylinders? I think I had a mix of 4s and 5s when I took mine apart.
| All times are GMT -8. The time now is 06:12 PM. |
