-   -   1975 RSR Replica up and running (http://forums.pelicanparts.com/911-engine-rebuilding-forum/635877-1975-rsr-replica-up-running.html)
txhokie4life 10-21-2011 12:51 PM
I acquired a 75' 911 RSR Replica.
The engine had suffered some head damage and scuffing of the pistons.
Instead of jumping into a compete engine rebuild I bought a 3.6L 964 street
engine and proceeded to do a top end refresh.
This was my first engine rebuild and my first experience with an air cooled engine.
With a lot of summer homework reading Wayne's book, encouragement from resources like this forum, and a mechanic friend lending me his shop and doing some double checking of my reassembly I had success firing it up this week.
The biggest challenge turned out to be reverse engineering the MOTEC 48 ECU and
harness system.
964 3.6L Long Block ReAssembly
http://forums.pelicanparts.com/uploa...1319226490.jpg
Long Block Complete
http://forums.pelicanparts.com/uploa...1319226645.jpg
Street Long Block, Race Engine Intake/Fuel System/Ignition
http://forums.pelicanparts.com/uploa...1319225675.jpg
Mated with G50
http://forums.pelicanparts.com/uploa...1319225617.jpg
Installed in RSR
http://forums.pelicanparts.com/uploa...1319225652.jpg
Video of Start Up
1975 RSR 3.6L Engine Rebuild - YouTube
Still have to chase down some non-engine oil leaks and have it tuned up.
Mike
PFM 10-21-2011 09:02 PM
Mike,
My guess is that is going to be FUN!!!!!!!!!!!!!!!
al lkosmal 10-22-2011 08:38 AM
Can you tell me what coil packs you are using....very tidy!
al
txhokie4life 10-24-2011 07:42 AM
They are Clewett Engineering coil paks.
Also Clewett Crank Pulley.
The ITB are from Borla who bought TWM.
I think the fuel rails are from them as well.
Mike
txhokie4life 10-24-2011 07:45 AM
Knocked out the majority of oil leaks over the weekend.
Plugged all vacuum leaks.
I've got tapping or clacking coming from my passenger side of the engine.
I'm just not experienced enough to know source. Maybe needs valve adjustment.
Will have to find a 911 expert to give it a listen.
Mike
txhokie4life 11-20-2011 02:57 PM
Tapping was from a rocker whose valve I had over tightened.
Went and had it tuned last Thursday.
1975 RSR Engine Tuning - YouTube
