-   -   pistons and barrels 2.2 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/640713-pistons-barrels-2-2-a.html)
56 nomad 11-18-2011 09:13 PM
hi ,
i need a little info. i am looking for some cylinders and pistons for my 71 t and member has some pistons and barrels i am thinking about buying ...his a sets are from an mfi engine are they compatible with my older case.
i only need 2 good ones, would i need do i need to change them all as well as changing the heads ?
thanks , ben
Flieger 11-18-2011 09:35 PM
Yes, as long as it is a 2,2 MFI engine they will fit fine.
Flieger 11-18-2011 09:36 PM
Just make sure the height groups are the same (that they are a matched set).
Flat6pac 11-19-2011 03:16 AM
There is no need to change the heads. The complete set should be used because there is a deck height that has to be the same to keep the engine sealed. I f you install 2 cyl of a different height theyre either not tight enough or the cyls are too tight leaving the other cyls unsealed.
All 2.2 and 2.4 T cylinders are the same size and cast iron.
Bruce
jbell959 11-19-2011 08:01 AM
2.2T pistons are different than 2.4T pistons. They are both 84mm but they can not be mixed and matched.
56 nomad 11-19-2011 08:04 AM
hi, what is the difference between mfi and carb pistons and cylinders, still no sure if there is one or not...ringed cylinder vs no etc. thanks for the education. ben
jbell959 11-19-2011 08:22 AM
There is more to that question then just carb vs mfi... All the MFI engines with the exception of the 2.4T used the Biral cylinders. The only MFI engine that used a cast iron cylinder was the 2.4T. So... the 2.2T and the 2.4T both have 84mm cast iron cylinders and they are both the same and interchangeable. However, the 2.2T piston and the 2.4T piston are not the same. One is designed for the 66mm crank in the 2.2 and the other for the 70.4mm crank in the 2.4. I don't have pictures of both but they are clearly different and not interchangeable. If you use the 2.4T pistons with a 2.2 crank you will have a very low compression ratio.
56 nomad 11-19-2011 08:46 AM
jbell969,
assuming i found some usable ones if they were "higher" could my machinist cut them down so they would have the same height as the originals? if i don't go that route are there reasonably priced alternatives...numbers seem all over the place.
thanks, ben
jbell959 11-19-2011 08:52 AM
Originally Posted by 56 nomad (Post 6380660)
jbell969,
thanks, ben
If you are talking about useable cylinders and they have a higher height group then yes, a good machinist can match they height to your other ones. However if yours are already the largest height group then you would need to get the same ones. You are probably going to need to pull all of them anyway to get a good matching set so I would consider replacing them all with a set that already matches. The pistons are another story... you need 2.2T pistons. There are no other pistons you can use in those cast cylinders unless you replace them all with an aftermarket piston like JE (but they need to be designed for cast iron cylinders).
You should be able to find a good used complete set of 2.2T pistons and cylinders for pretty cheap. Otherwise, you have a lot of options if you want to upgrade your engine. You can go with a set of 2.2E or even 2.4E or 2.4S pistons and cylinders. You can also find JE pistons and aftermarket cylinders for a reasonable price. It really depends on what you're trying to accomplish
Flieger 11-19-2011 09:41 AM
Now is a great time to upgrade to Aluminum/Nikasil cylinders. They are lighter and produce more net power due to lower friction. I did not read carefully enough. I thought he was going to buy a whole new set. Not just two cylinders.
56 nomad 11-19-2011 06:37 PM
thanks for the help everyone , i got my questions answered, ben
