-   -   Cylinder Head Temp Sensors (http://forums.pelicanparts.com/911-engine-rebuilding-forum/641287-cylinder-head-temp-sensors.html)
Weissach911 11-22-2011 11:19 AM
As the 3.0 litre SC engine we have is proving troublesome and needs a rebuild it seems like a good idea to try to convert the CIS to an EFI and I have been looking at various options.
I have been told by some guys in the UK that the Megasquirt system has problems with air cooled engines but there are several posts here on Pelican that seem to have dealt with this in a number of ways.
The 3.2 CHT sensor looks effective but I don't want to change heads.
Is there an effective way of fitting a CHT sensor on a 3.0 litre head or is there a better way of monitoring warm up.
jcge 11-22-2011 02:42 PM
Grady Clay has previously posted about installing thermocouples into each head by drilling a small hole and retaining the thermocouple with a roll pin (and epoxy - if I recall correctly) which allows the thermocouple wires to pass through the center of the pin.
mppickett 11-22-2011 04:36 PM
I've been using a megasquirt on my 3.3 turbo using a 3.2 CHT sensor for about 5 years with no problems. Just find a spot on the head out of the way of cold weather (under the shroud) to attach it (carefully drill a mounting hole in a fin if needed). I like it better than using the oil temp sensor for fueling accuracy.
turbo nut 11-22-2011 10:38 PM
I machined my stock turbo #3 head in the same location as a 3.2 head to accept a 3.2 temp sender. Works just fine. I,m also using a Megasquirt system.
proffighter 11-23-2011 12:43 AM
Used a Bosch sensor on my SDS EFI like other before
http://forums.pelicanparts.com/uploa...1322037832.jpg
proffighter 11-23-2011 12:46 AM
Another pic
http://forums.pelicanparts.com/uploa...1322038003.jpg
Weissach911 11-23-2011 01:28 AM
That look great - Thanks for the input.
Two Rivers 11-23-2011 04:04 PM
Aircraft 3.0L heads have a spot for a temp sensor. They are the same as automotive heads other then that.
If you need one I might be able to scare one up.
fanaudical 12-07-2013 02:21 PM
Resurrecting an old post: Two Rivers - Do you have a pic of where the CHT sensor got installed on those 3.0L aircraft heads?
jpilcher 11-01-2016 07:17 PM
How is this setup in Megasquirt?
H-viken 02-03-2018 01:13 PM
Lifting this thread.
I want to install 2 cylinder head temp sensors, 1 per cylinder bank. What type of gauge have you guys used and where did you place it? Looking for some inspiration.
I was hoping to find something that could replace the clock.
Johan
Tippy 02-03-2018 01:25 PM
Johan
Why, might I ask? EFI only needs them for warmup purposes. Are you running the other to a gauge?
H-viken 02-03-2018 03:26 PM
Not running EFI, but running carbs. My mechanic suggested including two sensors as an extra safety measure.
Johan
fanaudical 02-03-2018 03:38 PM
Westach makes a nice and affordable 2-1/4" dual CHT gauge that uses type J thermocouples:
Westach
I removed my ashtray and mounted one of these plus a voltmeter in its place.
H-viken 02-04-2018 06:25 AM
Thanks! Hadn't heard about Westach.
If I can't find something that fits where the clock sits, I was thinking ashtray or radio delete.
Has anyone modified the Fuel/Oil gauge and used it as a Temp gauge?
Johan
Tom_in_NH 02-04-2018 01:49 PM
+1 on the value of EGT sensing as an easy way to identify a misbehaving cylinder. Combining EGT with CHT would be the killer app for our air-cooled motors. Check this out:
12-Channel Digital EGT and/or CHT Pyrometer Gauge Display
Spenny_b 02-05-2018 10:51 AM
I'll shamelessly plug the AEM thermocouple interface/amplifier I'm currently selling.>>>
FS - AEM Thermocouple Interface/Amplifier
Guaranteed <1% accuracy at full scale...kind of important... ;)
I bought it when using an ECU that didn't have this function built into it natively (my new Syvecs can accept K-Type thermocouples directly into the ECU). The AEM unit has 4x input channels (I only used 2 of the channels, an EGT on each bank on the secondaries), then fed that output from the AEM into my ECU as an analogue input. Worked like a charm, no setup and it comes with the voltage vs temperature charts so you can calibrate the ECU. Uses K-Type thermocouples. In as-new condition, aside from not coming with the 12w Deutsch connector which we needed for my install....easily available pretty-much anywhere.
(Can also output data as RS-232 for data logging into a laptop - I am half-wondering whether to keep the unit and use it to monitor "whatever", as-and-when I need to....all sorts of uses that it could be used for on a more temporary basis; stuff that you may not need to monitor on an ongoing basis.)
lightbulb8817 02-05-2018 01:14 PM
Hoping you got your answer and others can chime in on a separate but related question...
How does the cylinder head temperature correlate to the engine oil temperature?
Reason I ask is because I'd like to program my front-mounted engine oil cooler to turn on when the oil temperature reaches a certain number (>210-220F). However, I would need an temp sensor somewhere in the circuit, which I'm having trouble tapping into cleanly. If the CHT somewhat correlates to engine oil temp, I'm thinking just use that as sensor to trigger oil cooler fan. In other words, does 250F CHT correspond with 210F engine oil temp generally speaking?
The engine oil temp wouldn't help with tuning your motor due to the amount of time it takes for the oil temp get up to adequate levels.
mikedsilva 02-08-2022 01:19 AM
Originally Posted by proffighter (Post 6388064)
Is this bracket available for purchase?
proffighter 02-08-2022 04:12 AM
No, DIY part, but easily self made. Aluminum U-Profile or block with cut-out and thread. No rocket science.
chrismorse 02-08-2022 07:48 AM
Oil temp does not have a linear relationship to engine temp, primarily because of the thermostat(S) in the system and the oil coolers. CHT would be much better.
I once ran washer shaped sensors under the spark plugs on a turbo 914, but had difficulty securing the washers reliably.
I believe Elephant sells an oil temp probe that is inserted in the fins of the cooler to switch a relay on to the fan.
chris
David Borden 02-10-2022 09:23 PM
Do you have the Bosch part number for that sensor? It looks as though you are using the end of the sensor to clamp the bracket and wedge the sensor tip onto one of the fins to hold it in place?
Walt Fricke 02-14-2022 02:31 PM
Looks like tightening the sensor clamps it all in place - clever.
mikedsilva 02-14-2022 02:35 PM
Might not be good for the sensor tho?
I'm wondering if there is enough meat in the head, to bore the 10mm hole, and thread it, so the sensor can go straight into the head itself...
David Borden 02-14-2022 07:07 PM
Walt, I agree... Seems very ingenious.
Mike, can you expand on your concern? I see a concern with pressure on the tip if the area below the threads is insulated and not one piece with the threaded area. I would think the direct contact is a good thing if one piece? I suspect the sensor reading would be more accurate with direct contact with the head. I do wonder if that specific sensor pulls the temp from the end/tip or an average of the whole sensor below the hex.
winders 02-14-2022 07:30 PM
Agreed...also, the sensor has a lot of airflow around it which would seem to cool it. The Factory head temp sensor is threaded into the head so the part of the sensor that measures the temperature is much less likely to have air flow cooling it.
Peter M 02-17-2022 01:51 PM
Mike,
Yes, good idea. Many bolt knock sensor bridges to the bottom of the heads successfully so there is no reason not to drill and tap for a temp sensor.
https://i.imgur.com/vGQGl8N.jpg
