915 Trans Swap in 1971 T
I am planning on pulling my 2.4 and 901 trans out of my 1971 911T and replacing it with a 2.7 and 915 trans.
Other than having to re-work the trans tunnel to accommodate the slightly larger diameter of the 915 trans in place of the 901 is there any other issue that I might encounter with the clutch cable and clutch operation using the original pedal to clutch linkage setup to this 915 trans? |
I don't know for sure, but I think the original 71 clutch was a push direction and the 915 clutch is a pull direction. Might need to re-work the cable routing or use a later cable.
-Andy
72 Carrera RS replica, Spec 911 racer |
You need a 915 shifter and shift linkage.
You also need to sort out the drive shafts, I think. If its a 76 or newer transmission you need an electronic speedo and wiring.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Thanks for the info, this 915 is a 1972 with mechanical speed "O". Didn't realize the cable and the push pull setup. Something I need to find more detail on I guess. Anyone out there know where I can acquire such detail on the cable swap for this conversion??
Thanks |
'69 warmrod T
![]() Clutch pedal is as original, clutch cable is now as spec'd for an '83 car. My 915 clutch release arm is the later type with the helper spring. You need a cable that corresponds to the age of your gearbox (assuming it has the original release arm) PET lists 911 423 401 00 for the 73MY onward which to my mind would be your gearbox. I had to change my output shafts to match the CVs on the axles. I'll reiterate you need both the 915 shifter and the 915 shift rod. Last edited by MdR; 12-01-2011 at 06:34 AM.. Reason: typong eroor |
Did you find pre-76 output shafts for your 915 or did you make a new flange on the existing shafts?
'69 warmrod T
The 930 output shafts have 6 x M10 bolts fixing for the CVs The '69 901 CVs have 4 x M10 bolts & 2 x dowels I drilled through the '69 CV dowel holes to accept M10 bolts, sourced two half moon plates and new Schnorr (sp?) washers. I also drilled out the CV tin boot cover. Kevin Roush @ GAS Motorsport & Grady Clay were both really helpful in passing on this information to me back in May
When I meassured the transmisions width flange-to-flange I found that the original 901 was 1 cm wider than the 915. But you used the original axles, the 5mm probably doesn't matter?
'69 warmrod T
The 915 conversion into an Early car seems common enough that I'm happy mine works OK. |
Interesting, haven't thought about the centerline!
Thanks!
