-   -   Where to find Piston Squirters in the US (http://forums.pelicanparts.com/911-engine-rebuilding-forum/643851-where-find-piston-squirters-us.html)
dwoods 12-07-2011 05:04 PM
I ordered from our host and they are not in stock and will take a month and cost a premium to get. Any ideas who might have them in the US? Thanks in advance.
porterdog 12-07-2011 06:38 PM
Did you try Sunset?
brads911sc 12-07-2011 07:40 PM
try a dealer? amazing what they have in stock sometimes...
MBruns 12-08-2011 06:58 AM
squirters
I have some in stock, if you have a part # or a outlet size and length I may have what you need
Mike Bruns
dwoods 12-09-2011 02:57 PM
Thanks all for all of the responses. I am looking for Part Number 93010101500 - the squirters for a 79 930 engine.
gtu935 12-10-2011 02:53 PM
why don't you upgrade to 964 squirters?
AlfonsoR 12-10-2011 08:24 PM
When is it good to change out squirters? I thought they should last quite a while?
boyt911sc 12-11-2011 05:09 AM
After you split the engine crankcase....
Alfonso,
Sometimes you could get the clogged oil piston squirter/s to spray better but in some cases cleaning won't make any difference at all. So an appropriate course of action while the engine case is apart, is to replaced the defective ones.
Tony
AlfonsoR 12-11-2011 08:53 AM
Thanks Tony. Is there a way to check squiters for flow? I guess some shops must have flow benches.
Another question, if you "upgrade" to 964 squirters, does that reduce flow/pressure to other critical areas?
