camshaft settings
i am putting together my first engine and i am trying to follow waynes book. on camshaft setting i have set z1 with dot on left camshaft up.
valve clearance set .1 mm rotated crank 360 set up my dial indicator as outlined in book ( 72 911 T motor needs 2.6mm) roated camshaft without pin in till dial indicated valve seat moved down 2.6 mm this is when i put pin back in and torqued nut i have vid if somebody could review it right side next |
right side i set z1 and the camshaft dot up. ( i think this should have been done when i set the left side up)
i rotated 360 after setting valve clearance put dial on and removed pin turned camshaft almost 1/2 a revolution and noted lift coming around z1 stayed and when i saw change in dial showing valve moved down 2.6 mm i put pin back in it feels like i did it wrong and worried about direction of rotation thanks |
| All times are GMT -8. The time now is 07:31 PM. |
